Is anyone experiencing an issue in Field Maps where it's not allowing manual location updates, even when the setting 'Allow manual location' is enabled? This is a related feature class, data collection.
thank you,
Ku Silva
Hi @KumuduDesilva,
Yes, I’ve seen this behavior in Field Maps with related feature classes. Even if Allow manual location is enabled, the option won’t always appear when editing a related record — it only shows when you’re updating the parent feature geometry. A couple of things to check:
Verify the editable layer is the parent feature class, not just the related table.
Make sure location editing is allowed in the map settings and sharing settings.
Test on a new web map — sometimes settings don’t fully carry over after schema changes.
If those don’t help, it might be a known limitation with related records rather than a bug in your setup.Regards,
Venkat
Thank you, Venkat.
