Previously, when I exported survey results, the records appeared in order of the pothole number. However, the exported data now appears to be exported by date order. Not sure the workaround to fix.
Thank you.
Not sure how your template is setup but there is sorting syntax that can be implemented.
https://doc.arcgis.com/en/survey123/browser/analyze-results/featurereportqueries.htm
https://community.esri.com/t5/arcgis-survey123-questions/sorting-fields-in-a-repeat-report-template/td-p/1485749
