We have been using https://survey123.arcgis.com/portalUrl =<Enterprise Portal>. sometimes, it does not open and throws survey not found error on the web browser. to avoid this, can we use windows survey123 app to open from another application through web link?
Hey @vijaybadugu
Normally, it doesn't work due to a problem connecting to the Portal itself, that being said, I'm not sure that using the app would change much since I assume they're on the almost same connection. I'd definitely be interested to hear the results if you give it a shot though!
Cody
Hi @vijaybadugu,
Could you try going to your portal organization settings > Security. Then, add Survey123 as an approved app in your portal?
https://enterprise.arcgis.com/en/portal/latest/administer/windows/manage-app-launcher.htm#ESRI_SECTION1_7D9954DF51FD47DAB4011E786ADF681B
If this answer solved your question, please mark it as "Accept as Solution" to help others who have the same question.
Cheers,kntr
