Greetings. In my survey i have a select_one question where the answers are populated via 'autocomplete search()' functionality. The 'name' value, that is the 'id' of the selected answer, is being stored in the survey's feature class as the actual answer to the question. The 'label' value of the selected answer is stored in the Survey as a calculated field but its esri:fieldType is 'null' so i think it's value is not kept when the survey is submitted.
Is there a way to get that 'label' value for display in the survey Report template. The 'id' value won't mean anything to Report readers; only the 'label' will.
Thank you
