Hi All,
I’m constantly struggling with performance issues in ArcGIS Pro that make even the simplest workflows take far longer than they ever did in ArcMap. Opening the attribute table of a layer with fewer than 200 features, moving a point 100 ft, or just panning the map — every single action triggers lag, a “Modifying Feature” popup, or some other loading icon. It doesn’t seem to matter if the data is stored locally or on a network drive — the response time is still sluggish.
In ArcMap, I could handle much larger datasets with near-instant performance. The forced switch to Pro has honestly been maddening — it’s tough to keep up with my workload when I’m constantly waiting on the software to complete the most basic tasks. At times it feels like I spend more energy fighting Pro than actually doing my work.
I’ve tested this on multiple machines with similar results, so it doesn’t appear to be tied to just one environment.
I can’t be the only one running into this, so I’d love to hear from others:
Are you seeing the same level of sluggishness with relatively small datasets?
Have you found any specific settings (rendering engine, indexing, hardware acceleration, caching, etc.) that noticeably improve performance?
Is this truly just the nature of Pro compared to ArcMap, or could there be deeper configuration issues on my end?
Is there a way to connect with someone at Esri who can help assess my setup and confirm whether this is my machine or simply how Pro behaves?
Any insights, tweaks, or workflow adjustments that have made Pro more responsive would be greatly appreciated.
Thanks in advance,
Nick
System Specs:
ArcGIS Pro version: 3.5.0
OS: Windows 11
CPU: Intel Core Ultra 7 165H
RAM: 32 GB
GPU 1/2 : Intel Arc Graphics / NVIDIA RTX 2000 Ada Generation Laptop GPU
Storage: 500gb
