Hi all I need help with publishing a print service tool from ArcMap to ArcGIS Server 10.9.1 Federated. So that I can utilize the print service in ArcGIS Online Experience builder. Just an overview- I can't downgrade ArcGIS Pro to 2.9 and I can't upgrade ArcGIS Server to 11.3 due to compatibility issues with existing workflows. I'm currently limited to the following setup:
ArcGIS Enterprise (federated) 10.9.1
ArcMap 10.7.1
ArcGIS Pro 3.3
I published a printing service from ArcMap, but when trying to use it, I received the error:
"Web map as JSON is required."
What could be causing this issue?
When testing the tool from the Rest Service I get the following error.
Job Status: esriJobFailed
Job Messages:
- esriJobMessageTypeInformative: Submitted.
- esriJobMessageTypeInformative: Executing...
- esriJobMessageTypeError: Failed.
- esriJobMessageTypeInformative: java.lang.Exception: Could not service request.
