I would like to calculate drag curves/ swept paths for a very long truck which transports rotor blades of a wind turbine. Is there a possibility to do this in arcgispro in a simplified manner for a line feature class?
I don't know of a tool that would do this for you out of the box.
You could write something in Python.
You can iterate over features in a feature class using a search cursor, and you can iterate over parts of a geometry to get the individual vertices of a line. With this, you could iterate over the line, get each vertex, draw a line segment starting and ending at the appropriate length between that vertex in the direction of the previous one.
import arcpy # Set the path to your line feature class line_feature_class = r"C:\Users\myusername\Documents\ArcGIS\Projects\MyProject6\MyProject6.gdb\Streets_feat" # Create a SearchCursor to access the geometry # The SHAPE@ token returns the geometry object for each feature with arcpy.da.SearchCursor(line_feature_class, ["OID@", "SHAPE@"]) as cursor: # Iterate through each row (feature) in the feature class for row in cursor: object_id = row[0] geometry = row[1] print(f"Processing Feature OID: {object_id}") # Polylines can have multiple parts (e.g., multipart lines) # Iterate through each part of the geometry for part_num, part in enumerate(geometry): print(f" Part: {part_num}") # Iterate through each point (vertex) in the current part for pnt_num, pnt in enumerate(part): # Check if the point is not None (handles interior rings in polygons, though not applicable to simple lines) if pnt: print(f" Vertex {pnt_num}: X={pnt.X}, Y={pnt.Y}") else: # This case would generally indicate an interior ring in a polygon, # but for simple lines, it signifies the end of a segment within a part. print(" Segment break within part (not a vertex)") print("Vertex iteration complete.")
Thank you for the code and explanation. But I think the further steps exceed my python possibilities. There's specialized commercial software like autoturn or heavyGoods:
https://autoturnonline.com/?gad_source=1&gad_campaignid=910989046&gclid=EAIaIQobChMIp_vNkPH3jgMVR4KDBx0OUAZ8EAAYAyAAEgKxCPD_BwE#vehicle-turning
https://heavygoods.net/de/apps/swept-paths
Autodesk's Vehicle Tracking, a swept path analysis and design software, might be worth looking at.
