Hello all,
After completing the Create the Utility Network tutorial with the sample electric database, I attempted to do the same with some test data of our own. However I am running into an error during the Asset Package to Geodatabase step. The error is : C_Associations association_type 1 None Field must have a valid value error. Is there a way to examine the C_Associations and their values? I ran the tool with the Structure and Electric Domain boxes checked, and with the option to Load Data checked. The previous step in the tutorial is Sync the C Tables Asset Group/Type, and appeared to have completed successfully. Any information tracking down this error would be much appreciated.
Anthony
ArcGIS Pro 3.5.1.57366
untools 3.5.0
Executing from ArcGIS Pro, 2 map(s), activeMap = True
Parallel processing enabled: 9
Asset Package schema version: 3.3
