Any idea why I would be getting the Maximum supported error for a Pie Chart when I only have 13 categories. My data is a Eurl from Cityworks. See screenshot below. The same data displays in the serial chart above the pie chart
@CodyPatterson
It's weird because when you look at the slices tab you only see the categories you would expect.. It's thinking that each feature is a separate category
Hey @JerryWilson
There's something definitely wrong with the grouping of the categories, I think they may not be grouped similarly as the serial chart. Check out these posts here:
https://community.esri.com/t5/arcgis-dashboards-questions/dashboard-pie-chart-data-limit-exceeded/m-p/1049025#M4405
https://community.esri.com/t5/arcgis-dashboards-questions/quot-data-limit-exceeded-quot-even-if-under-50-000/td-p/1634654
Could I see the setup of the pie chart? Maybe I can spot something out!
Cody
