Hi Team,
I hope you all doing well!!
We are facing an issue related to ArcGIS relational datastore. The ArcGIS Data Store on hosting machine is currently non-functional. The internal PostgreSQL instance fails to start with the following error:
"Error encountered: No valid connection to ArcGIS Data Store configuration store established.
Caused by: Connection to localhost:9876 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections."
Log of the Database
2025-07-22 08:31:41 IST: [3960]: [104-1] CONTEXT: line 40 of configuration file "D:/arcgisdatastore/pgdata/pg_hba.conf"
2025-07-22 08:31:42 IST: [2388]: [1-1] LOG: database system was shut down in recovery at 2025-07-22 07:47:15 IST
2025-07-22 08:31:42 IST: [2388]: [2-1] LOG: invalid primary checkpoint record
2025-07-22 08:31:42 IST: [2388]: [3-1] PANIC: could not locate a valid checkpoint record
2025-07-22 08:31:43 IST: [3960]: [105-1] LOG: startup process (PID 2388) exited with exit code 255
2025-07-22 08:31:43 IST: [3960]: [106-1] LOG: aborting startup due to startup process failure
2025-07-22 08:31:43 IST: [3960]: [107-1] LOG: database system is shut down.
Could you please help me in resolving the issue.
Thanks & regards,
Kristofer
