I am using Survey123 Connect 3.23 to build a survey with an autocomplete search function. The question pulls from the results of another Survey123 form through a REST endpoint. I have the autocomplete search question working properly, but I need to add a filter to the results to only show entries from the past 7 days.
I have a 'submitted date' field in the 1st Survey123 form that I am trying to use to filter. The way I have tried to filter the results is: submitted date > current date - 604800, after the main text in the 'appearance' field.
I have done a good amount of research and trial/error and I cannot come up with the correct syntax to get this question working properly.
Thank you!
