How can I enable snapping of a new polygons created in a local feature layer to feature layer added from portal?
The source of the portal layer is redactedname.maps.arcgis.com/home/item.html?somelonghash
I have added the "portal layer" to the current map, which appears as a group containing point, line and polygon sublayers, some of which I want to snap to. However when I add a new polygon to my feature layer, with snapping enabled, it does not snap to the "portal sublayer".
