Is it possible to configure a popup template on the FeatureLayer service itself so when the JS API is using the service it is defined, or must you always define it only in the JS?
Hi @joshk6656 -
Yes we highly suggest that you do this! This is the easiest way to configure a popup and consume it in other applications (such as a JS Maps SDK app). You can configure the popup on a feature layer item and then consume that popup in a JS SDK application by loading the feature layer from the portal item. Here's the steps to do so:
Hope this helps!
