Hello All,
Can someone tell me how to address the following TypeScript error:
const view = new MapView({ container: mapDiv.current, // ERROR: "Type 'WebMap' is not assignable to type 'MapProperties'." map: webmap });
JSAPI version 4.33
Thanks!
Found it! You have the old AMD types installed too, remove those and you should be good.
https://github.com/CI-CMG/pointstore-dashboard/blob/main/package.json#L21
Probably want to remove "src" from includes in the node tsconfig too
https://github.com/CI-CMG/pointstore-dashboard/blob/main/tsconfig.node.json#L27
Thanks for the suggestion and your offer to help Rene. Re-creating the node_modules and package-lock.json file did not seem to help.
Here's the repo: git@github.com:CI-CMG/pointstore-dashboard.git
Tried this out with a new vite TS app and not seeing this. Could you try deleting your node_modules/package-lock.json/yarn.lock and try again? If you have a github repro, can take a look.
Thanks for your reply. Yes, it looks like this:
const webmap = new WebMap({ portalItem: { id: "43b93cc9be994efbb5a60a2b2d85f151" } }) const view = new MapView({ container: mapDiv.current, // Type 'WebMap' is not assignable to type 'MapProperties'. map: map });
I wonder if I'm missing something in my VSCode configuration then?
Is your webmap constructed using `new Webmap`? I don't get a typescript error in my application using arcgis 4.33 with equivalent code.
