After the new version update. I am trying to geocode a table of addresses with the updated ArcGIS Pro 3.5 version.
The Geocoding Addresses Geoprocessing Tool is not working as expected. All addresses are going into the Unmatched Address category, and it's not creating a point feature class.
Is anyone having this same issue? Provide your thoughts and solutions.
Tech Support is your best option. They will have to confirm your setup, geocoding base source and they would be better equipped to address changes that may or may not result from the esri side.
good luck
You can't, you have to file a tech support case, assuming that you have those capabilities or if you are in an organization, the person involved will have to do it for you
How are you assessing "not working as expected"
Is it because the addresses dataset geocoded properly in a previous version of Pro? or is it because it just didn't work?
Yes, I ran the same dataset in previous version pro before major released this year. Its working and geocoded all dataset.
Hi Dan. I had the exact same issue as Pandiyan today. Think it might be the version I have (3.5.0) as it worked perfectly on the older (3.3). I will download the latest update and see if that does the trick.
How can transfer this community questions to ESRI support team?
Same issue running 3.5.3Geocoded tables running on previous versions are not working anymore. All unmatched. I'm going to open a case.
