Hi All,
Help me out I am lost on DNS, Webadaptor and so on.
We upgraded our gis server so now IT is helping us point the public url to the internal one.
Our web adaptor is https://example/server/
I requested the below
If we point https://example/arcgis/rest/services to https://gis.example/arcgis/rest/services .would we need to update our web adaptor?
Correction*
It's a new environment instead of an upgrade
Yup. That’s why you’d need the second dns. I see this stuff all the time where enterprise deployments evolve rather than being planned. There are some fundamental planning steps that are often overlooked. Maybe I should write a book one day….
sorry you’re struggling.
Is gis.example your ArcGIS Server or Web Adaptor? It isn't completely clear to me the hostname of the machines involved.
Background our ArcGIS Pro and Server is federated. We are on 10.9.1.
gis.example is how we access the rest service on an external network.
@Scott_Tansley If you have any comments, it would be extremely helpful.
The dns has no bearing on the web adaptor naming it’s just the example.com bit. So some example from my dev setup…
portal is installed on https://portalvm.int.local:7443/arcgis
server is installed on https://servervm.int.local:6443/arcgis
web server is web3. Two web adaptors, portal points to the first machine. Server points to the second. Both use the fully qualified host names.
hub.geoworx.co.nz is my dns entry. Internally I have an A Record pointed to 192.168.1.2.
Externally I have an internet record for hub.geoworx.co.nz that pointed through to
my router then has NAT instructions that points request on 443 to to 192.168.1.2.
All DNS entries only relate to the hub.geoworx.co.nz element.
Another consideration is that (I assume) your server is pre-existing and a hosting server. This n which case you cannot change the context of the web adaptors. It must be the same after upgrade as before.
BTW - apologies for delay. I’m currently travelling around Europe and had missed this.
Thank you Scott,
The server is a fresh install and is federated with portal. The old server utilized the https://gis.example/arcgis/rest/services, currently IT is trying to figure out how to replace it with new server. Do you have any documents that I can share
Appreciate your help!! @Scott_Tansley
You need to access it internally using exactly the same URL.
Yes, definitely. Thank you scott for troubleshooting with me.
