I created a roads layer using Line Map Notes. I'm having trouble converting into a shapefile. Any ideas?
I made a new set of Line Map Notes in Pro 3.4, added some simple lines and exported them to a shapefile (attached) using Export Features. I didn't see any issues with the process, are you able to clarify what trouble you ran into?
The line notes don't transfer and I get this
Odd, if you select one or two features before exporting does that change things?
It doesn't seem to. I have to go back in the properties and set the original feature as the data source to get it to work. But it doesn't seem like that'd be the right answer for exporting.
hmmm
it may be worth trying to Paste Special into a blank shapefile or gdb feature class?
