Good morning,
Is there a way to query the related records in a layer definition query in ArcGIS Pro or a Web Map. I some cases I want only so select records that have a specific value in a related field.
In ArcGIS Pro, you cannot directly query a related table in a Definition Query. Definition Queries are applied at the layer level and work with the attributes of the layer itself, not its related tables. With that said, I believe you can use the Make Query Table (Data Management)—ArcGIS Pro | Documentation geoprocessing tool to create the query layer and have it stored within your ArcGIS Pro project file.Although this is an ArcMap resource page, here are some examples of making a query table - Examples of queries with the Make Query Table tool—ArcMap | Documentation
@SanchezNuñez
Adding a reference to another discussion on same/similar topic. I hope if this might help
https://community.esri.com/t5/arcgis-pro-questions/arcgis-pro-definition-query-to-select-a-group-of/m-p/1300418
