I linked a map to use for offline instances, and see this error:
Some documents say to make sure the map is in WGS 1984 Web Mercator (auxiliary sphere), which this is.
Anyone else come across this?
EPSG Geodetic Parameter Dataset - Wikipedia
EPSG:4326 is a datum for the geographic coordinate system
EPSG:3857 is the web mercator projection of 4326 data
Hi @dwold,
Adding to what Dan said above, please consult the online documentation:
https://doc.arcgis.com/en/survey123/desktop/create-surveys/preparebasemaps.htm#:~:text=Survey123%20supports%20the%20use%20of%20offline%20basemaps.%20These%20basemaps%20must%20be%20of%20a%20supported%20Esri%20file%20type%20and%20use%20the%20Web%20Mercator%20Auxiliary%20Sphere%20projection
If you are using any type of packages, check that the data is in the same Web Mercator Auxiliary Sphere projection
Regards,
Glen
Were you actually able to solve this? I am getting the same error message despite my map being WGS 1984 Web Mercator (auxiliary sphere) as well.
