Good morning -
Where can I find documentation on the supported version of Utility Network for Enterprise 11.5 ?
Thank you,
Amy
Esri has not yet posted any documentation for ArcGIS Enterprise 11.5, but it is supposed to be available this month. 11.5 is a long term release so there may be a new Utility Network version, but that does not always happen. The ArcGIS Pro 3.5 help documentation still mentions Utility Network version 7 as the latest version.
https://pro.arcgis.com/en/pro-app/latest/help/data/utility-network/utility-network-compatibility.htm
The page you linked does all out compatibility for 11.5 in all three sections of the help topic (the UN version one is a bit tricker because 11.5 falls into 11.3 or later).
Support for subtype group layers improves with each release, but most customers have been able to work around the limitations of subtype group layers and exb by publishing a web map using regular feature layers that either don't split out their layers, split out their data into a handful of layers, or in the case of 11.5 you can use scale-based display filters to control the visibility of features based on scale without SGL.
@RobertKrisher Has there been any more update with Utility Network and Enterprise 11.5 compatibility? The Utility network compatibility page still has no mention of 11.5. Just found out my Enterprise 11.3 Experience Builder is not compatible with Group Subtype Layers and all my Utility web maps are set up with Group Subtypes, I'm not excited about the idea of having to completely reset up these maps without Subtypes Group Layers just so I can use the widgets in Experience Builder. May continue to live in WAB until 11.5 upgrade.
@AmyCleare this information will be available once ArcGIS Pro 3.5 and ArcGIS Enterprise 11.5 release. As a reminder, you can find the existing documentation about utility network versions and backwards compatibility on the Utility network compatibility page.
