When I create a Network Dataset in both ArcMap and ArcPro with the same data and same settings (I think), i get slightly different results. Specifically for Drive Times. The polygons results for the drive times will be slightly different in Pro than what I got in ArcMap. It can be different by 700 feet. There's a possibility the settings I'm setting up aren't exactly the same from the two programs, but if they are are exactly the same, should they produce the same results? If so, I need to really look into my setting on Pro to find out which settings I'm not matching to ArcMap.
Since the process to create a Network Dataset is a little different from ArcMap and ArcPro, is there something I need to really catch that I'm missing? It's a slightly vague question, but I'm hoping there might be a simple answer.
