Good morning,
Is there a way maximize the popup window when a user clicks of a feature?
We have a popup that has only 6 fields and the suer would like to see the whole list together.
Hi @SanchezNuñez,
There isn't a way to manually change the size of the Popup. Since it lives within the View, it's best to not take up too much space. It is a known limitation from JS API.
Please use the Feature Info widget instead.
Ke
Good morning @Ke_Xu
I tested adding a feature info widget, with the jewelry template, adding the widget in the slide and it works.
