Hi!
I'm in Pro 3.4.2. I just received a bunch of messed up shapefiles from an outside party. They were first displaying in Oman when they should be in CA. I was able to define projections (2 different ones) that worked w/most of the files but I have a couple left that just won't display. When I zoom to layer, the map navigates to where they should be, but there's nothing there. I've tried different color combos and manually investigating the area, but there's nothing. Considering the scale of the area displayed when I zoom to layer, they are pretty large, there's no way I would miss them.
I found an esri technical support doc for a similar problem that suggested clearing cache in the program and in temp files, so I did that, closed out of Pro, reopened, and there's still nothing there.
Any ideas??
Thank you in advance!!!
