Can drive time polygons be used to create geofences in Field Maps?
Thanks.
Jim
Hi @JimWooten
I think you should be able to do this you will need to set the layer up against the geofence.
Get started with geofences in ArcGIS Field Maps
@JimWooten do you mind explaining more about your planned workflow? For example, how you are generating the drive times and where and how they might be used with Geofences? I am curious about the use case. To answer your question, the layer just needs to be hosted in order to use it as Geofence features.
