FieldMaps crashes when selecting date on iPhone. I tried it on Android and it works just fine. Not sure what is going on. Everything else works. Any ideas?
It is an existing date field from the geodatabase. format is mm/dd/yyyy time
To clarify, did you add the date field when creating the Form, or is it an existing date field from the geodatabase? What is the date formatting? Thanks!
Hi!
Ok, do it by writing some sort of expression.
https://community.esri.com/t5/arcgis-field-maps-questions/populating-createddate2-field-with-created-date/m-p/1552211#M9818
Good luck.
Well, the date can be different than the then when it generated, so I would still need a date field.
The date, the creator, the edit date, object ID and more fields generate by Field Map itself. So, you do not need to add these field when customizing your Field Map form.
