I've created a used "import 3D object" from the "geoprocessing" toolkit in a local scene to place a 3D object at a certain geo-location. The 3D object I want to share/export to ArcGIS Online using "Share as a web layer" has the following info:Data Type File Geodatabase Feature ClassDatabase C:\Users\user\Documents\ArcGIS\Projects\MyProject4tesrt\MyProject4tesrt.gdbName testAlias testObjectID 32-bitFeature Type 3D Object V2 (Simple)Geometry Type 3D Object V2 (Multipatch)Coordinates have Z value YesCoordinates have M value NoAttachments No AttachmentsFeature Binning DisabledCompression UncompressedVertical Units MeterMinimum Client Version 3.1 / 11.1But something fails and I get the error: 00396: The dataset version is later than is supported by your server. Minimum version: <value>How can I solve this? I've already checked out this page: https://doc.arcgis.com/en/allsource/1.1/production/00396-the-dataset-version-is-later-than-is-supported-by-your-server-minimum-version-value-.htmlMy idea is to host a digital twin (3d model of a building) and then update it with new 3D objects using the python API. The first step would be to have our 3D model in a suitable datatype and from what I've heard that would be a "hosted feature layer with multipatch geometry"?
Hi @desiree
The error message is noted here in the following article 00396: The dataset version is later than is supported by your server. Minimum version: <value>
You need to be aware of where and what version your data is coming from, also the version of ArcGIS Pro and environment you are attempting to publish to.
