Hi all,
At my client we maintain a survey in Survey123 to gather all kinds of rail related issues. In some cases we need a secondary geometry for a begin point and an end point. Therefore we use the option to fill in a first geometry and a secondary geometry (bind::esri:fieldType=null). We extract the secondary point geometry into a text field with a calculation :
pulldata('@geopoint',${pointgeomEnd}, 'DD')
The secondary geometry is mandatory. However we allow the users to edit the feature by linking back to the map with this code for the popUp:
<p>
<a target="_blank" rel="noopener noreferrer" href="https://survey123.arcgis.app?itemID={survey_item_id}&update=true&download=true&action=edit&q:globalId={globalid}&field:aangemaaktOp=">Gebrek bewerken</a>
</p>
The first geometry is preloaded, but the secondary geometry stays null. I understand why, but how can I get this preloaded? Is there another field/calculation that I can add?
To illustrate I have added the example excel in the attachments.
Hope someone has encountered this before.
