We are preparing to set up ArcGIS Monitor 2024.1 or the latest version when we begin. We will be monitoring nearly two dozen servers.
Previously we had ArcGIS Monitor 10.8 set up in a Dev / Prod configuration where the Dev version was primarily intended to test upgrades and configuration changes before applything them to the Prod version. They essentially monitiored all the same servers and services. In that version, there was no Monitor Agent installed on the machines being monitored.
Now that a Monitor Agent is required on each server to be monitored, what is the recommendation for a Dev / Prod configuration?
- Can the Monitor Agent connect to two different ArcGIS Monitor hosts?
- Can two instances of the Monitor Agent be installed on each server to be monitored?
- Is a Dev version of Monitor even recommended?
