I don't see a way to control the zoom? I don't see a property to do so. This has no effect:
<arcgis-search position="top-left" zoom="10"></arcgis-search>
You can do this by listening for the sources collection to change.
https://codepen.io/odoe/pen/gbOqrXv?editors=1000
const searchElement = document.querySelector("arcgis-search"); // component loaded, might still be loading data await searchElement.componentOnReady(); searchElement.allSources.on("change", () => { searchElement.allSources.forEach((source) => { source.zoomScale = 100000; }); });
Hi @Noah-Sager, yes I am aware of the transition. My goal here is just that. I'm creating an app using components, not widgets, to get a leg-up on my functioning custom apps that will need transitioning.
Hi @JaredPilbeam2, you may need to use the widget property to do that currently. We're in a transition process with components and widgets. I believe you want the goToOverride property,
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#goToOverride
Yeah i think that service does require a token or to sign in, I just copied it from the doc and didn't try and run it. I see a few layerview creation errors in your codepen, but I don't think that would affect the search. I'm not sure what's going on I'll have to look into it more closely
Thanks for the reply. That doesn't seem to have any effect on the zoom either? And it's asking me to sign in. Does it need a token? Sample.
Hi @JaredPilbeam2 ,
The zoomScale is set in the zoom components sources property
<arcgis-search id="search" position="top-right"></arcgis-search> <script type="module"> const searchElement = document.getElementById("search"); searchElement.addEventListener("arcgisReady", () => { searchElement.sources = [ { url: "https://geocode-api.arcgis.com/arcgis/rest/services/World/GeocodeServer", name: "LocatorSearchSource", zoomScale: 1000000 } ]; }); </script>
