The Python standard library includes the csv module, which you may be helpful to you as it will not convert data on input. You could read and append your csv data using Python lists, create a table with the schema you want, and then add the data to the table using an insert cursor. In this way you could bypass all the schema.ini jazz.
... is there a way specify field types in python where the finished CSV file would not require a schema.ini file to import fields in the correct format such as: date, Long, Double and also control the field width.
