Using Survey123 connect 3.22.49 and survey123 field app 3.22.53. How can I disable or hide 'Save in Drafts' button as well as draft box on field app? Please kindly confirm. Thank you for your support.
I have looked in both Survey123 Connect and the Survey123 app, and there does not appear to be an option to disable "Save in Drafts" in the app. However, you can Enable/Disable "Save in Drafts" in the web app, as the Draft is saved as a cookie.
There may be a backend solution to it, but not directly within Connect or the App (that I can see).
