Is ArcGIS License Server Administrator 2022.1 compatible with ArcGIS Enterprise 11.4?
Here is a matrix, that helps define the LM version based on your version of Pro: https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-arcgis-pro-licenses.htm#ESRI_SECTION1_B534D464350F43FDA277B746F1E6EF36
Are you using the Named User license or concurrent model for Pro licensing?Being honest, I would probably update the LM to the latest version. That is usually a low risk update and fairly quick. I would always have a backup of the machine before the upgrade, in case you need to roll back.
Yes Sir, I will update it as well. Thank you.
