<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title></title> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/js/esri/css/esri.css"> <style> html, body { height: 100%; width: 100%; margin: 0; padding: 0; } body{ background-color:white; overflow:hidden; font-family: "Kimberley", sans-serif } #header { -moz-border-radius: 5px; border-radius:5px; margin:5px; padding-top: 4px; padding-right: 15px; background-color:#211E21; color:#FFC98C; font-size:16pt; text-align:right;font-weight:bold; border: solid 2px #2A2F30; height:55px; } #subheader { font-size:small; color: #cfcfcf; text-align:right; padding-right:20px; } #map { margin:5px; border:solid 4px #2A2F30; padding:0px; } .shadow{ -moz-border-radius: 6px; -webkit-border-radius: 6px; border-radius: 6px; -webkit-box-shadow: 0 8px 6px -6px #999; -moz-box-shadow: 0 8px 6px -6px #999; box-shadow: 0 8px 6px -6px #999; } </style> <script>var dojoConfig = { parseOnLoad: true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.4/"></script> <script> dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.map"); dojo.require("dojo.number"); dojo.require("esri.layers.FeatureLayer"); dojo.require("esri.dijit.InfoWindow"); var map, trailLayer; var template; var soeParams; var soeURL = "http://sampleserver4.arcgisonline.com/ArcGIS/rest/services/Elevation/ESRI_Elevation_World/MapServer/exts/ElevationsSOE/ElevationLayers/1/GetElevationProfile"; function init() { //This sample requires a proxy page to handle communications with the ArcGIS Server services. You will need to //replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic //for details on setting up a proxy page. esri.config.defaults.io.proxyUrl = "../proxy/proxy.php"; map = new esri.Map("map", { basemap: "satellite", center: [-117.069, 36.215], zoom: 13 }); var infoWindow = new esri.esri.dijit.InfoWindow({}, dojo.create("div", null, map.root)); map.infoWindow.resize(625, 240); infoWindow.startup(); map.setInfoWindow(infoWindow); //setup SOE parameters soeParams = {}; soeParams.ImageWidth = 600; soeParams.ImageHeight= 200; soeParams.BackgroundColorHex="#ffffff"; soeParams.DisplaySegments=false; soeParams.f="json"; //add the trails feature layer to the map template = new esri.InfoTemplate(); template.setTitle("<b>${notes}</b>"); template.setContent(getTextContent); trailLayer = new esri.layers.FeatureLayer("http://sampleserver5.arcgisonline.com/ArcGIS/rest/services/LocalGovernment/Recreation/MapServer/1", { mode: esri.layers.FeatureLayer.MODE_ONDEMAND, infoTemplate:template, outFields: ["*"] }); //create a new renderer for the feature layer var lineSymbol = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID,new dojo.Color([0,255,0,.70]), 5); trailLayer.setRenderer(new esri.renderer.SimpleRenderer(lineSymbol)); map.addLayer(trailLayer); //add world place names to the map var referenceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer"); map.addLayer(referenceLayer); } //Generate the content for the info window when the feature is clicked. function getTextContent(graphic) { var geometry = esri.geometry.webMercatorToGeographic(graphic.geometry); var deferred = new dojo.Deferred(); //generate elevation profile soeParams.InputPolyline = dojo.toJson(geometry.toJson()); esri.request({ url: soeURL, content: soeParams, callbackParamName: "callback", load: function(fset) { deferred.callback("<img src='" + fset.profileImageUrl + "'/>"); }, error: function(error) { deferred.errback("Error occurred while generating profile"); } }); return deferred; } dojo.ready(init); </script> </head> <body class="claro"> <div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%; height:100%;"> <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'"> Click a trail to view the elevation profile </div> <div id="map" data-dojo-type="dijit.layout.ContentPane" class="shadow" data-dojo-props="region:'top'"></div> </div> </body> </html>
