I have a Master Survey that is broken out into 3 separate surveys. Each of the three surveys are built from the Master Survey. The surveys are filled out consecutively, with the Field survey creating the first entry, and then two surveys done in a lab setting that build off that field entry. For the two lab surveys, I am using the Inbox feature to edit the existing entry. However, none of my calculations are running in the Inbox. They all work when I open the survey without the Inbox, but once in the 'edit' mode of the Inbox the calculations don't run (even when I click on the refresh button). I've seen other posts from a few years ago detailing how users have made all of their calculation questions 'calculate' and then created a separate 'note' that displays the calculation. However, I have a lot of calculations, and creating duplicates all of these questions would make the Master survey table very unwieldy. Am I missing an easier way to make these calculations run?
