Map tools do not displayed when using mapRef.
const mapRef = useRef<HTMLArcgisMapElement>(null);const graphicLayer = new GraphicsLayer();
const generateWebMap = async (map: MapType) => { const mapEl = mapRef.current; const webMap = await getWebMap(map.mapId); if (webMap && mapEl) { const mapView = new MapView({ map: webMap, zoom: config.Zoom, container: mapEl, }); const sketch = new Sketch({ layer: graphicLayer, view: mapView, visibleElements: sketchVisibleElements, }); setMapView(mapView); setSketch(sketch); sketch.on('create', handleSketchCreateAction); sketch.on('update', handleSketchUpdateAction); if (creationLayer) { sketch.on('delete', handleSketchDeleteAction); } }};
useEffect(() => {const actualMapFromProject = maps?.[0];if (mapRef?.current && actualMapFromProject) generateWebMap(actualMapFromProject);}, []);
<div css={styles.wrapper(isWebMapOpen || isChildTab)}> <ArcgisMap ref={mapRef}> <ArcgisEditor /> </ArcgisMap> }</div>
If you can provide a github repo showing the issue, might be able to help. From your snippet, I'm not sure why you're creating a new MapView and using components, it should be one or the other.
If you use React 19, you don't need the map-components-react package.
Here is a React 19 sample
https://github.com/Esri/jsapi-resources/tree/main/component-samples/map-components/samples/react
Hi @IrynaBabych, there's an easier way to work with components, here's an example using Sketch:
<arcgis-map basemap="topo-vector" center="139.5716,35.696" zoom="18"><arcgis-sketch position="top-right" creation-mode="update"> </arcgis-sketch></arcgis-map>
https://developers.arcgis.com/javascript/latest/sample-code/sandbox/?sample=sketch
