I have a search widget Experience Builder with two search sources. One is the ArcGIS World Geocoding Service. The other is a layer in the map. I have the layer search set to allow searching on two attribute fields. These same two fields are set as the display fields. This search will work for either of these fields exactly once. Subsequent searches for the same value return No results found for "[searched value]". Reloading the page will allow one search again but then the same behavior repeats. Could this be a bug? What settings should I check to try to correct this?
