Please support using multiple attributes for labels with newline and concatenation capabilities similar to ArcGIS Pro.
Marc
Hi @Marc_Graham,
Thanks for posting this Idea.
For this item, have you considered a LISP approach? For example, you might consider using LISP to select multiple attribute values and then create/relatively position a label for each selection.
For considering a LISP approach here, before incorporating commands, please note that those such as Esri_PickLabel create links between the attributes and the TEXT/MTEXT entities. See additional details here: https://doc.arcgis.com/en/arcgis-for-autocad/latest/manage/feature-linked-labels.htm
Hi @MichaelDavidsonPM
Ideally we are after a straight forward approach to making slightly more sophisticated labels that is easy for the end user.
Two common use cases:
While we're not planning in the near or medium term to add a user experience for this functionality, we are considering adding a LISP sample to our repository that will allow for newline and concatenation behaviors.
@MichaelDavidsonPM Not sure if you ever made any headway on that LISP sample for generating labels from multiple attributes but I would also be very interested. Right now we are looking into a service with query layers that have fields that are concatenations of other fields.
Hi @TheRrrr42, thanks for expressing interest in this. We are planning to have this sample in place in the official repo in 2026. I will follow up with you via direct message as well.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
