Hello, good morning so in the tool results HTML file, under Best parameter combination backbones: resnet152, however under Best Performing Model Report, Backbone: resnet50. So which backbone model should be chosen then? reset 152 or resnet50?
Please refer to the complete report while interpreting the results, as it is divided into three sections, each providing different insights:
Summary:
In your case, when AutoDL tried to perform parameter tuning in advanced mode, it identified ResNet-152 as the best backbone with the other stated optimal parameter combination. However, it's important to note that this doesn't necessarily mean ResNet-152 is the best model overall; it's just the best when paired with the parameters chosen by AutoDL during the tuning process.
The overall results indicate that ResNet-50 performed better without any parameter tuning. Therefore, based on the evaluation metrics, I recommend selecting ResNet-50 for the best performance, as it outperforms ResNet-152 in terms of actual results.
