Just wondering if there is an appetite to be able to automatically create a linear feature (in my case the line of a pipe) from breadcrumb data collected?
I have a .xlsx file with pipeline inspection data that I can manually turn in to a pipeline feature on ArcGIS by manually joining the dots, but there a hundreds of points to join. In my case I want to use all the girth weld locations to fix the shape and location of the pipeline.
It's be fantastic if there was an ability to click 'select all' on the field you want to use and ArcGIS Online does the rest.
Also it'd be even better if there was a way to smooth out the line in the event there was an errant reading, or the ability to remove that from the feature layer.
