Did you find another way to extract from a raster using a polygon mask?
The old-style results window came up! �?? you know the one that shows a progress bar and gives reports in courier text. And when failing to execute, the dialogue box came back with my inputs.
I was searching on "extract by mask"to resolve a similar problem - extracting LULC data for a number of circles so that I could characterize LULC within a certain radius of a point. The extraction would produce a grey scale raster without an attribute table, and it was the attribute table that I needed for my analysis.
By trial and error, I figured out that the extract by mask always fails when the output file name starts with a number. When I used letter characters instead for the output file name, it worked. I don't know why this is so, but I've not had problems since I started naming my output flies with
Paul, this because most raster tools use the esri grid format for intermediate results, sometimes even when the output is not grid. The grid naming rules are:
I know it's old school, but I try to follow these rules for all dataset and field names when possible. (Actually field names I try stay under 10 because, shapefiles.)
