hallo community.
i try to compare 2 field with number and want to know in every row if tha numbers equal or not
can i get here simple code block to get this result?
regards
itay
you are missing the example and the code block you used
perhaps you could just create a simple integer field and use something like
def compare(a, b): """compare 2 fields and return 0 for different, 1 otherwise""" if a and b: val = 1 if a == b else 0 return val return None
expression compare(!a!, !b!) where `a` and `b` are your field names enclosed in ! marks
thank you Dan
it's really work 🙂
good,
perhaps you could go back and click Accept as Solution on my response
