Using Survey123 version 3.21.66
I design a survey using repeat and in box.
The problem field is a "select one" question with a choice_filter.
The choice looks like
| result | name1 | label1 | Y |
| result | name2 | label2 | Y |
| result | name3 | label3 | Y |
| result | name4 | label4 | Y |
| result | name5 | label5 | Y |
| result | name6 | label1 | N |
| result | name7 | label2 | N |
| result | name8 | label3 | N |
| result | name9 | label4 | N |
This works fine when collect data.
However, when open the record from inbox, the data in field always disappear.
I check the database in smartphone, and the record is fine.
So it's must be the APP.
