I'm running into an issue with the Experience Builder Foldable theme template, specifically the Search parameter.
I've chosen to "Interact with a Map widget", enabled "Customize search sources", and selected "New search source" from "Layer source".
The layer I would like to use as a "Set layer source" is not listed amongst my other layers, however, this layer is part of my web map.
Has anyone else run into this issue? If so, your advice and guidance would be most appreciated.
Thank you.
JD
