I'm trying to set up a print widget in Experience Builder, on my ArcGIS Enterprise. It works fine... when all my layers are off. It'll print out the basemap no problem, but when I add my hosted feature layers it refuses.
Errors given are minimal, even in logs. Basically comes back with:
Error executing tool. Export Web Map Task : Invalid input. Failed to execute (Export Web Map). Failed to execute (Export Web Map Task).
I imagine this must be down to permissions, but I don't know which. The feature layers in question (hosted on my ArcGIS Enterprise) are available to everyone in my organisation, and shared with relevant groups. The print service is shared similarly. I'm logging in as a user (in Experience Builder) that has access to the same groups. And as I say, it is printing (just not the layers), so it shouldn't be a problem with the print service, but instead the layers in question.
As an aside, when I tried to add the print widget initially, Experience Builder could not find the default one - I had to go into "Add Utility > Items" and locate it in there.
I feel like I'm missing an obvious "gotcha" in regards to sharing, but I can't think what.
