We have upgraded an application from 10.3 to 10.4 and now get the following error -
BC30643 Property 'ESRI.ArcGIS.Geodatabase.ITableSort.Ascending(Field As Boolean)' is of an unsupported type.
Per the documentation @ http://desktop.arcgis.com/en/arcobjects/latest/net/webframe.htm#52284974-38c8-4272-b5a2-f56f38ad94a2.htm
for tableSort.Ascending
[VB.NET]
' Set ascending property with field name and Boolean value.
tableSort.Ascending("State_Name")=False
In 10.3
WriteOnly Property Ascending(Field As String) As Boolean
WriteOnly Property CaseSensitive(Field As String) As Boolean
In 10.4
WriteOnly Property Ascending(Field As Boolean) As Boolean
WriteOnly Property CaseSensitive(Field As Boolean) As Boolean
This appears to be a bug, but if not can you explain how ITableSort.Ascending is supposed to be used in 10.4
Darell
