Hello, I have a problem with FGDC metadata in feature classes that reside in SDE geodatabases.All interaction between Desktop and SDE happens with version 10 products.Here is what happens:1. I have a feature class with FGDC metadata (has not been upgraded to ArcGIS Metadata)2. I merely want to edit the ArcGIS Metadata so that its title is identical to the FGDC counterpart.3. I use ArcCatalog and the new metadata editor to put a title in the ArcGIS Metadata.4. I see that the title has been updated, and that the FGDC metadata has not been changed.5. I click to another feature class, look at its metadata, and click back to my original feature class.6. The title in the ArcGIS Metadata has disappeared, along with the entire FGDC metadata record.This happens with Service Pack 1, Service Pack 2, and the recently released Service Pack 3.Has anyone experienced this?
We have the same problem (V10 SP3) and one quick fix that seemed to work for us is after updating and saving, we also validate(press the validate button on the top menu.) The newly added metadata stays ! -Deepti
Can you double check whether this feature class is registered with geodatabase? You can find this out by right-clicking on the feature, and check whehter "Rgister with Geodatabase" is disabled or not.If it is not registered with geodatabase, register it and try edit the metadata again. See if the metadata stays after registration.Eugene
Glad to know I'm not entirely crazy. I have tried to register the feature classes and still the metadata disappears.
We are having the same problem. Our Metadata just disappears. ArcMap 10 SP3, Sequel Server 2008. After adding metadata (by the way it takes forever for the metadata to load in Catalog, sometimes 30 seconds for a few tags). The metadata somehow gets deleted after saving. Validating only deletes the metadata. This is extremely frustrating to have to constantly add the metadata over and over again hoping it works. exporting and importing does not work either. Upgrading the metadata does not fix the problem.
Has anyone seen this issue with 10.1? We had a number of feature classes that had metadata and lost it but not all feature classes lost it. We are SQL Server 2008R2.
Most of our featureclasses that had this happen just sitting in SDE. Only thing I can think that acts on them is our Geodatabase Maintenance routine (Compact/Rebuild Indexes/Analyze). Could that cause lost metadata? Could this be affected by moving in and out of feature dataset?
-Hunter
