DistanceGeodetic isn't working in QuickCapture. Will trigger in the designer, but blank on actual capture. The Distance function does work, but is not what I need.
Unsure if it's related to the same issue listed here: https://community.esri.com/t5/arcgis-field-maps-questions/distancegeodetic-not-working-in-fieldmaps/m-p/1523237#M9323 Figured I would throw it out there as an issue.
Also - the help resource for the function within the Arcade editor has a different capitalization format than the current function.
The following worked for me:
