It appears there is a small UI/UX problem in the GotoXY dialog.
On decimal degrees (dd) and decimal minutes (ddm) settings the labels for the Long and Lat fields are correct and correspond to the fields for data entry. On the degrees, minutes and seconds (dms) setting the text box labels are reversed but not the fields.
Consider changing the dms labels to be consistent with the other 2 lat/long types.
Hello @ThomasHoman , I don't see this problem, also using Pro 3.4.0. Are you using a particular coordinate system, or any unusual Options settings ?
Hi @ChrisUnderwood no, nothing special. I just tried in on another users Pro 3.4.0 machine that just got software installed today and the problem is not shown so more than likely what I am seeing is corruption in my installation somehow. Next stop uninstall and reinstall.
Thanks for inquiring.
Tom
Hey @ThomasHoman ! Thanks for submitting this Idea. We looked at this and couldn't reproduce the behavior. That being said, Idea Exchanges are not the right place to log software bugs or crashes. Keep in mind that just because it isn’t the right fit as an Idea does not mean that we aren’t here to help. Bugs and crashes should be logged with Technical Support. You can learn more about ArcGIS Ideas Submission Guidelines and Statuses here.
Meld je aan om te posten, content te volgen en meer. Nieuw hier? Registreer gratis.
