I’m experiencing an issue where my points are not visible in Survey123 after connecting a feature service to my survey. Here are the details of my setup and troubleshooting steps so far: Basically what I am doing is I already have a map of hydrants, I added certain fields as questions with a domains, I want the workers to modify those fields, however none of the points are showing up in survey123 connect, even though fields populated.
Setup:
Troubleshooting Steps Taken:
Additional Information:
Has anyone encountered this issue before, or can you suggest additional troubleshooting steps? I would appreciate any guidance to resolve this.
Thank you!
Survery123 only displays the points collected through Survey123. If you want to view existing data and edit rather than just add data look at field maps and using their forms or integrating Survey123 with Field Maps. For more information on integrating these two tools, you can check out this community thread.
Thank you
