Need to run rules like Check Geometry on all feature classes in different Datasets in a file geodatabase.
In ArcGIS Pro 3.4 there a two workflows for implementing this and depending on the number of feature classes to be validated one may work better than the other.Note: if this is the only error condition you need to evaluate then you might want to consider using the Check Geometry tool instead.
Scenario 1: I need to run Check Geometry check on many feature classes in my geodatabase.
Scenario 2: I need to run Check Geometry check on just a couple of feature classes in my geodatabase.
Hope this gets you started.
